No Network issue
sumitbaran
No Network issue
Sony Xperia Z2 D6502 no network issue start after 5.1 update.
10 REPLIES 10
profile.country.PH.title
MarlonUk1
did you update using PCC? try to perform a software repair
sumitbaran
Already done. Update by PCC. Repair by PCC.
Tags (1)
MarlonUk1
make sure you are in an area of good signal.. try to check your network settings
settings>mobile networks>preferred network type ( try to set it to gsm only then set to your preferrence.)
check your network operators set it to auto.
sumitbaran
Preffered Network - GSM Only = No Signal, Preffered Network - WCDMA Only = 1 or 2 / 3 Bar Signal. But in my Sony Xperia M4 Aqua, Preffered Network - GSM Only = Full Signal, Preffered Network - WCDMA Only = 2 or 3 Bar Signal.
MarlonUk1
Jake-SonyXperia
Hi SBM1971.
Can you test with another SIM card and let us know the result?
sumitbaran
I have test with so many SIM cards, like new and old, many network providers etc. But nothing, same issue.
sumitbaran
I have test with so many SIM cards, like new and old, many network providers etc. But nothing, same issue. My Xperia M4 Aqua has geting good network from same place.
Jake-SonyXperia
If you have tried multiple SIM's and repaired the handsets software, then I can only advise that you seek help from Customer Care. Use my signature below to find appropriate contact details.
