No camera hardware key
profile.country.PH.title
MarlonUk1
I just have been reading reviews of Xperia Go, I was taken aback by one detail. NO CAMERA HARDWARE KEY? but still on the review it says it can still take photos under water... how?
12 REPLIES 12
JohnSt
IEC 60529.
What is it you don't understand? The test is submersion in fresh water for 30 minutes with the bottom of the device positioned at 1 meter depth. If you start moving the device then the pressure being exerted is no longer equivalent to that of 1 m submersion. Moving water also changes the pressure. Try sticking your finger into a cup of stationary water, then holding it under the tap, then in front of the nozzle of a pressure washer. Feel the difference? The first test will get your finger wet, the third test will injure you.
andyactive
john what you are forgetting is that inorder for it it to recieve a ip 67 rating is that it should also pass all the other ip tests before it,including the ip 57;test which is "powerful water jests at all directions on the device, at 100 liters a minute at 100 kpa for 3 minutes". which is effectively 8 pressure washers on it for 3 minutes.
the go is completely sealed , the rubber linning cannot be desturbed like other water resistant phones. then there is the additional back cover which reduces pressure on the rubber seals.
the weak points are the ports imo.
heck the go is said to be more resistant than the active and sony showed people surfing with the active, in their promo.
that is well over 1m of pressure on the phone when you combine the act of fallling in the water with the waves.
MarlonUk1
I could not explain it better than andyactive had.
both Xperia Active and Go have the same certification.
