I have the xperia tipo dual and did the update to 11.0.A.6.5, I have the problem, that the phone no longer connects to the wlan, when it is turned on. wlan is turned on, my ssid is listed but it just doesnt connect. I have to turn off/on wlan in order to get a connection. Then, everything works fine. Even if I leave the house and come back after some hours, it directly discovers the known ssid and connects immideatly.
This problem did not exist with the older firmware (I think it was 11.0.A.1.8).
Did anyone experience the same?
Any way to downgrade?
Juergen
Have you tried to forget the network? Long press on the SSID and chose to forget then add it again.
Now check if it will auto connect.
