I cannot connect 3g anymore, today at 1600 it just stopped working. if I select the 3g t-mobile option it confirms it registers with the Dutch T-mobile network but after that no app connects to the mobile internet. All the APN settings I verified with the operator seem ok
I have already hard reset the phone to factory twice
and run the latest version software I am sure, the phone specifies that and PC companion also
does anyone have any ideas??
1st do you have a data plan?
2nd make sure you have WCDMA preferred
3rd check the 3G coverage area with your carrier.
1. yes
2. checked still the same
3. yes, i am in my neighbourhood where there is extensive coverage by t-mobile. the thing is everything has been working for over a month now upuntil today
should i check with the operator? seems the only option left?
it might a faulty SIM card, get a brand new "MICRO" sim card, do not cut/trimmed a sim card.
yes but I can make phone calls and haven t moved the sim card nor dopped the phone since i got it 1st of march
I've seen similar issues were the SIM card do work to make calls and send sms but not mms nor data. it doesn't hurt to get a new MICRO sim card
I have to go to the store anyways i am out of options now
enter the APN settings manually but most likely its the SIM card also
uninstall any
taskiller
antivirus
battery apps
i swapped the sim card the service attendant confirmed as well that can happen that the card malfunctions
it worked initially and android seemed to identify only a 3 g network to which it connected but when i started roaming through Amsterdam, settings reverted back to the the 2 g network. i can then manually change to 3g again, it then holds for about 5 minutes and then goes back to 2g
mad annoying i have no idea what to do now
@uliwooly: would you reckon this is a software problem, a hardware problem or a network issue??
i have sent a query to t-mobile a specialist is investigating, but what that means if they can t find faults on their side, they are going to fault the phone meaning I have to swap the device probably
