Short story:
1. Bought Sola
2. Service centre after 2 weeks for PCB replacement.
3. Got back after 2 weeks.
4. Service centre again for touchscreen problem and low receiver volume.
5. Got back after 6 days (kudos)
6. NFC not working.
7. Tried repair by both PCC and SUS.
8. Service centre again?
What... No...
How you determine that NFC is not working?
When the phone stops reading all tags...?
same thing happened with me,they got it repairedand now its light is not turning off automatically while calling , i dont know maybe it is called proximity sensor, how can i enable it again in xperia sola??
What you need for NFC...
Tags (of course!)
Phone with NFC support
Liveware Manager / Smart Connect app (NFC application)
Try enabling NFC in the Settings > Wireless and something menu...
Next, download the LiveWare Manager app from Google Play Store...
Depending on your Android version, you will either have LM (2.3+) or SC (4.0+)...
Check whether you get these and report back for further instructions...
Regards,
Trubo
Check the NFC test in the service menu.
*#*#7378423#*#* > Service tests > NFC.
If it fails I suggest that you contact your local support team to check how to proceed.
Tried
Nothing happens when I "place it close to a tag"
It's already been in and out of servicing 2 times, and everytime it comes out with some new kind of problem... Is there any way I can get the set REPLACED not repaired? Cos I'm really tired and I don't think this set is gonna work fine ever.
