NFC not starting
Bains
NFC not starting
Hello
I recently got my Xperia SL's motherboard replaced from the Sony service center.
However, when I tried to switch on NFC yesterday, the check sign came on for a second and then turned off, and no matter how much I try, it does not switch on permanently.
I also tried repairing the phone through PC Companion but no luck as yet. Any help please?
7 REPLIES 7
Thommo
Genius
Try Settings then just under Data usage tap on more then tap the box to tick NFC
Bains
Hi Thommo
That is the issue !! When I click on the NFC check box, it shows "ticked" for a second or two and then becomes "unticked" . This was not the case before I got the motherboard changed.
Thommo
Genius
I see, I thought you were talking about the tools widget - If it's still not working then this is because it can't turn on something that isn't there - I'm guessing based on experience with Pc's and Laptops that they forgot to reconnect the NFC antenna or the NFC antenna became disconnected during re-assembly hence why it won't turn on,
The below image should explain what I mean - where my crude red arrow is pointing to is the NFC connection cable - If this is damaged or wasn't connected then this is probably the reason for the issue you are having - You can either disassemble yourself and check the cable connection or take it back to the service center and get them to connect it properly
Bains
Ah bummer !!:smileyrolleyes:
I should have seen that coming, since they forgot to connect my notification light too.
Thanks Thommo :smileysmileythumbsup: . I'll check this with the service center on tuesday and get back to you
Bains
other thing. The image you sent is just a triangle Slightly_frowning_Face
Thommo
Genius
Try this img link if it's still not working http://img703.imageshack.us/img703/1621/eqpk.jpg
Bains
Thanks !! I'll check this Slightly_smiling_Face
