NFC not enabling
Raffounz
NFC not enabling
Hi, i have a problem with NFC, it doesn't enable any more. I waited for Lollipop to see if this was some "software" issue, but it seems error persist.. I attach a video done with the new screen capture feature.
https://youtu.be/R0VN7QI7Rfg
Tags (4)
2 REPLIES 2
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Don't forget to backup
