NFC doesn't work
J0KER
NFC doesn't work
Hi, I have a problem with NFC, I live in Iran and a month ago back glass of my Xperia Z1 cracked because of my brother by the way I replaced new back glass cover and now my NFC doesn't work.
I don't know why this happened to me !?
Any idea how can I fix this problem?
Tags (1)
3 REPLIES 3
Hampus
Have you checked that NFC is activated via Settings > More... > NFC? If yes, have you tried to use the NFC function with different units? Otherwise, I suggest that you perform a software repair on your phone via PC Companion:
http://www.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
J0KER
Yes I checked and I have a question: Is software repair needs fast Internet connection?
Jake-SonyXperia
The software process does require an ADSL connection, however it does not have to be super fast to achieve this task.
