NFC does not recognize TAG
Tanzer
?NFC does not recognize or even see nxp ntag 203. Samsung s4mini does. What is the problem with Sony z3 compact?
Tags (1)
19 REPLIES 19
@Tanzer
Boot on safe mode and report back
SergioPL1
Check if you have NFC enabled and phone is in unlocked state. Z3-series doesn't display NFC icon when enabled/disabled.
Tanzer
Thx, Sergio, but NFC icon is there, reading does not work...
Tanzer
Thx, according to the link z3c should support ntag 203... Mine has problems
SergioPL1
I don't know how to help you :(. Before answering your question I tried to read old NX1 tag and it worked fine, detected "Home" and launched Smart Connect.
Maybe try to reset Smart Connect settings? Of course you will need to re-enter all your smart settings.
John-BR
Hi Tanzer
Welcome to the community.
I would suggest checking to see if this is a potential hardware problem. To use Xperia Diagnostics
Go to Settings > About phone > Diagnostics.
Tap Test device.
Select the NFC
Follow the on-screen instructions.
Could you let us know what the results of that are?
If it fails the test have a chat with your contact your Local support team as it will need to be serviced.
Tanzer
Hi, John... Test passed. However... According to specs ntag203 should be supported, but it does not...
Tanzer
Could it be android issue?
