Netwrok Problems
SonyXperiaFan
Netwrok Problems
Since a few months I am facing Netwrok problems and my cell is out of coverage.
My phone is on WCDMA(preferred)/GSM Network selection.
Another option is to us GSM Network, when I use GSM as my network this problem disappears but than I have issues with 3G servcies. My servcies convert to 2G from 3G.
I am located in Ahmedabad, Gujarat, India and my service provider is Vodafone.
Can someobne help me on this?
5 REPLIES 5
Thommo
Genius
Have you spoke to your network and checked that there are no issues with the coverage and you would be best taking your phone into their store and having it tested
SonyXperiaFan
Yes, under thoer guidance only I am aware of the 2G/3G faracas.
I was using 3G servcie and started facing network issue so I talked with ppl and got a solution to chnage to only GSM in network options.
My internet got slow and converted to 2G but my calls were all coming through. So I contacted the provider to improve my internet and thus he informed me that 3G servcie works only if you select WCDMA/GSM a snetwork option.
So it is under the supervision of Servcei Provider. If theree wa swevcie issue either way than changing the network options should not alter the same.
pita1978
I also used to experience this problem with Xperia z1... Many friends used to tell me that my phone is out of coverage area when they used to call me....last week cleaned up my phone using repair option on Sony pc client. Now it seems this problem is no longer there. However I have noticed slightly linked problem.... Most of the time my phone shows either remains on 2G network or it remains on lower speed bands of 3G and shows as H instead of H +. if it shows H and I start using data it jumps from H to H+. Today I m travelling to my native place and my phone is hardly getting 3g signalls.... It used to work fine with my Xperia z as well as with z1 before upgrade to latest..... Additionally it shows as R instead of H+....earlier I have not seen R when I used to roam at my native place.
SergioPL1
Your Xperia has two operation modes. One is 3G, second is 2G.
In 3G mode you can have high speed data transmition modes H+, H and 3G (slowest, 384 kbps). In GSM (2G) mode you can have either EDGE (which is up to 224 kbps afair) and very slow, very first GPRS mode (up to 96 kbps, depending of network conditions).
These days using GPRS mode is barerly unusable, it is too slow to do anything but due to lack of coverage or free network spots (too high load on BTS stations) phone may fall back to this mode from time to time.
Second thing is priority. Voice is always highest priority for the network so if there is not enough space in GSM (long distance, low speed) first your connection will be dropped to GPRS, then dropped altogether to leave space for voice connections. Also during a voice call in GSM mode data connection will be dropped and restored after the call.
3G mode is superior to GSM, it's much newer standard (called UMTS initially) but many operators have lot's of issues in dynamic switching between 2G and 3G coverage. Most notable symtoms of that behaviour is connection lost during call or inability to receive call (user not available or out of network) despite the phone is connected.
I personally had few issues with 2G/3G switching in two different operators here. First time was faulty SIM card, latter was general problem of network operator in few BTS stations (connections were almost always dropped in some areas). Of course it refused any responsibility for that but after few months situation has changed so it had to be network problem.
When you are on 3G network you can have H or H+ symbol but generally it is the same technology, only more channels are used. So H+ is only activated when real transmission occurs, when in standby it switches back to H to reduce battery use.
R means roaming so either your operator changed agreements of roaming within your country or has some misconfiguration in it's network and it also may cause troubles with connection.
iamthestig
Dude, Vodafone's network in India **bleep**. They always have problems with 3G or something else. Switch to Tata Docomo. Such problems are almost always related to the network, not the phone. If you can make and receive calls properly and browse on 2G then your phone is fine.
