Network setting is changed to WCDMA Preferred when connected to Wifi
Erisis
Network setting is not changed at little time, but seems to be changed when Wifi is connected for a long time.
Is there the solution?
Model:C6903
Customization Version;1276-7948_R5C(HK model)
6 REPLIES 6
Jake-SonyXperia
Hi Erisis,
With the information supplied, I can advise that this is likely related to an application changing the setting. I suggest that you try use the handset in Safemode and see if the issue continues.
1. Turn handset off
2. Turn handset on
3. When you see first splash screen hold down Volume Down key until handset is completely on.
To turn Safemode off simply turn the handset off and back on like normal.
Let us know if the issue continues.
Younisace
Hi Erisis, have you changed the default setting to WCDMA Preferred?
I have my WiFi on most of the time and my settings haven't changed
Erisis
It was not dissolved in Safemode...
Other than the information that I showed before, is there the necessary information?
Erisis
don't change setting into WCDMA Preferred.
Default setting is LTE/GSM auto(PRL).
Jake-SonyXperia
This could be related to a third party application or software not working correctly. I first suggest performing a factory Data Reset on the device to help remove any issues software wise.
Menu > Settings > Backup & Reset > Factory Data Reset > Untick box to remove all data
Make sure to backup your handset before attempting this task, please use the link below to perform this function.
Backup & Restore
I hope this helps.
Erisis
I tried it, but there was not the effect
When I use Softbank( cell-phone carrier), this symptom seems to occur than it.
I refer to SoftBank.
Thank you, everybody.
