Sim card is in and recognized, but I have no service. I tried factory reset and nothing. I can't even search for network's it is just searching all time... Any ideas how to fix that ? I put my phone in water, and it was working properly then it restarted and it sad no service... Water didn't get in I'm 100% sure... Please help
Nothing is gonna work, I got the same problem long time ago and nothing worked, the technical service never found a solution either. So, they gave me a new one (now it doesn't work though but that's another story 😕 ). Try to get in touch with Sony or your mobile company.
Good luck
Hi, I also find out that when I try to call somebody it said that i need to turn off airplane mode, but it is off, and under the settings it said that is radio off, i tryed tu tun it on but nothing. Did you have warranty ?
@Unregistered user
That seems to be a hardware issue, you should contact your Local support
