I'm getting network problem even after I've upgraded my phone to ICS. It was expected that this signal problem have fixed with ICS upgrade. Can someone please advice if this this can be solved?
there are many threads for this issue, please search through them.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
Hi Arnab, thanks for the reply. But as per the previous discussions in hte forum I had set my mobile network as GSM instead of by default WCDMA/GSM and MANUAL selection of operators. But this wont help as well, whenever I'm on the move my phone is unreachable. Please suggests me how you guys fixed this...I'm absolutely getting fed up with this issue..
i also did that manab86..still i have that network problem,,i already did that phone repair on update service and pc companion. pls help !!
did you try out with a different SIM? I am asking this coz I am also in India and using 3g 24X7, but I never see any signal drop or anything of the like. Its strange, But then again I use french ICS.
im from philippines. ya i did try other sim,,still i have that damn network problem...even my brother using xperia GO has that problem.
The problem is I'm not getting aware of the fact that my phone is unreachable. Because there is no sign of network signal drop or anything like that. signal bars are very much visible.Everytime I've to restart or do a Airplane mode ON/OFF to make my network active...
ya actually we do not have a problem with it cause i never saw my signal icon drop when the network problem appear..it is ok. im just bothered that it always appear,,its like 6x a day,
Can anyone please help what is the solution of this problem ?
