Network problem in- xperia sp
rahulec040
From past few days i am experiencing network problems.I am not able to access internet/make calls as the network sometimes  comes in and goes off near mayur vihar 1 delhi.
I changed my sim card also to a new sim card and also tried to place the sim card in other phone.
to my surprise the network is fine in other sets.The phone is only 5 months  old.
Please suggest solution
Regards
Rahul
manjuboyz
Hi rahulec040
   its really good you have tried trouble shooting, since you have tried much enough, keep data backup and try to repair the phone once by connecting to the computer , any software glitches will fix this issue
>try this too, settings -> Mobile Networks(which can be found under More.. too) -> check network operator is automatic, if not change to automatic along with that, tap on network mode then check which option is selected, WCDMA preferred/GSM check this option, restart phone and try using it
Manjuboyz :smileyhappy:
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks :smileyhappy:
