That's normal, that your phone goes to LTE (preferred)/WCDMA/GSM
4G does use more battery, your phone will look for the best connection, if you are in a poor network coverage area you might consider to turn off your data, also you might want to check with your carrier/network, they might be able to give you other APN settings
