Network Issue
Nishant979
Network Issue
Sometimes my phone doesn't search network automatically and needs to be restarted. Is this normal?
12 REPLIES 12
Thommo
Genius
It could be that your Sim is faulty or dirty
Nishant979
I am using a new sim.
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Is it a micro SIM card or did you trimmed a regular SIM card?
Nishant979
Micro sim
Follow Thommo's advice
Nishant979
I thought that lollipop update would solve the problem but it still exists.
Thommo
Genius
If you think it is a hardware fault then you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Nishant979
I don't know whether it is hardware fault or software fault. Before Xperia Z2 I had Xperia Z and never faced such an issue with that.
