neo
neo
Neo: why the update the list is not update?
18 REPLIES 18
check the SI thread if your number is not there
http://talk.sonymobile.com/message/199355#199355
If you find your SI in the released software table the software for your device is released and available in PC Companion and Bridge for Mac where you can update your Xperia™ Smartphone.
We will continue to add items in the list as soon as they are released.
We will however not be able to answer on questions like: "When will SI number XXXX-XXXX be added to this list?" or "when will country X get the update?"
if you MUST have it right now
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
before you update thest the new Dialer app and see if you are ok with the lag, bc it will increase once you get ICS
http://talk.sonymobile.com/message/164329#164329
nrebola
Hi.
But there's no update since June 8!!!!
Slightly_frowning_Face
just be patient you will get it, did you tested the Dialer app? what do you think of the lag?
The SI Number list is not updated from last 8 june whats the problem .
have you checked again?
nrebola
Hi, That's ok.
Still wainting...to android 4.0.4.
Tks.
did you tried the apps?
