hello there....i've tried using this link to root and flash my xperia mini pro running ics
{GUIDE} How to Root Xperia™ Smartphones
http://forum.xda-developers.com/showthread.php?t=1601038
but the thing is after i followed the instruction my phone became like black screen with the backlight glow brightly.....how can i undo this??what happen to my phone??is it brick??
please help me,,im new to this stuff and i dont know what am i doing...please anyone help me undo my mistakes :'(
ouh yeah..i've tried repairing it via SEUS but the software cant detect my phone :smileysad::smileycry:
please help me mate
nobody wants to help me??
repeat the whole process, follow the steps here
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
thanx for the info..but for the steps that required me to press and hold the back button while inserting the usb cable, am i suppose to press the back button or there is other button that can be press for example the volume down key..because xmp has touch back button right..it doesnt have any back button like xperia x8 etc..im confused..
Hello ahmadfaiz
When performing the SUS repair the button to Press and hold is the Home Key.
We don't provide info on rooting the unit as it may damage it like in this case...and the process voids your warranty.
We recommend you run Pc companion repair to try to fix the issue.
Run the Pc companion Software
Turn the phone off and disconnect it from the computer
1. No matter what the program says do not connect the phone until you complete step 9
2. In the welcome screen if asked click on start, Next you will be shown what media go offers, click on "next" then you will see a presentation on what support zone offers, click on "Finish"
3. In the next section from "support zone" and "media go" new select "support zone" and click on start.
4. On the next page select "Software update" and click on "start"
At this point if you get an error stating that "unable to install update components" or "server is busy" Please proceed to step 12
5. The program will say that there is no phone connected and will ask you to connect but disregard that and instead choose the option to "repair Phone".(the program will issue you a warning on the content that you will lose during the update)
6. Choose the option to continue.
7. After that, the program will download the necessary information (5 to 6 minutes) and it will present you with a list of phones.
8. Choose the Phone from the list (close to the bottom of the list) click on the icon for the phone and then click on "next"
then you will see a new section telling you how to connect the phone. (don't connect it yet)
At this point the phone must be off and disconnected from the PC.
9. Connect the cable to the PC not to the phone, then follow the instructions on screen to connect the phone, if done correctly the program will say "the update of your phone has started..." (in some cases a message of "Installing drivers" will appear before the message of "the update of your phone has started..." is shown.)
10. If you failed to follow the steps correctly the phone will turn on and it will request that you "Proceed with the following steps, slide down the notification bar", If this happens disconnect the phone from the cable, turn it off and repeat from step 9).
11. If the PC Companion proceeds correctly wait for the update to finish and follow instructions on screen.
Dear customer,
12. If "unable to install update components"
1. Close Pc companion
2. Install Java from: http://www.java.com
3. start Pc companion again and try to do the software unlock process once more.
Hope this helps
Francis
okayh..thank you so much.. i really appreciate your help
thank you so much again..
