Navigation/locations problem
nagendra_badam1
hi team\friends,
my navigation is not working after updating to 15.0.A.1.31
do anyone faced same problem.
my internet is working fine & i have activated all gps & location based access from the settings.
but still when i open navigation , it is continuously searching as "waiting for location"
it even not allowing me to set the destination place.
even when i tried to find the location in temperature widget, it says "could not find your location"
plz help me or suggest .
Alexander1
If you only have GPS-enabled, not Google's location services under settings > location services it might take longer for the GPS to find your position. In that case you should try to enable Google's location services.  Also you have to be outside for the GPS to find your position.
If you still not receiving any position I recommend that you open the service menu by pressing *#*#7378423#*#* in the dialer. Go to service tests > GPS > purge assistance data. Restart your phone and try again.
