I think that I have another problem. My Xperia needs four hours too full recharge. Is it normal or not? I think it is too slowly.
The device has a 3200mAh battery.It depends on what adapter you are using.If it is the EP880 with 1500mAh,it is too much.If you charge it via usb,it is fine.
With how great this battery is, I don't mind how long it takes to charge, its the time it takes to discharge that makes me happy!
It is a crap set. I will not recommend any one for it. Sony only publicating happly for its big battery capacity, this piece takes hours to charge to 100 %. Even after 4 hours some times it is not fully charged.
Don't think to buy this set.
hi guys.. my xperia z2 got a problem.. i charge 11pm until 7am but is not full. can help me what the problem is? my xperia z2 like this since updated os marshmallow
Was the charging time perfectly normal before the update & are you still charging it in exactly the same way ie thru wall socket or USB to your computer with exactly the same charger/cable, also did you notice the change immediately after the update
If so to all of the above....first of all try charging it in Safe Mode to see if there is a difference but stick to the usual percentage of battery showing that you normally recharge from.
If there is no difference then perform a software repair with XC then do exactly the same with regards to recharging :smileysmileywink:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
http://support.sonymobile.com/global-en/xperiaz3/tools/xperia-companion/
