My Xperia Z1 won't turn on and keep vibrating when connected to charger or PC
ximahmoud
Hello,
my xperia z1 battery was drained off. i charge it with a galaxy charger but it didn't work then after went home i charged it with the original charger and tried to turn it on but it didn't, i left it over the night to charge then i woke up on a 3 continuous vibration sound, it kept vibrating till i disconnected the charger but it didn't turn on at all.. and every time i tried to put it to charge or connect it to pc with its USB cable it keep vibrating till i disconnect it.
i don know if this could caused the problem but i used it to film videos in the pool but it was working very fine after that for more than 3 hours then when the battery was totally empty this happened.
i tried mostly everything. i tried pressing volum up/down with the power button, i tried the red button beside the sim card slot, i tried connecting it to the pc with PC companion running repair but nothing work. it won't turn on, nothing from the LED indicators, just RED & Blue flickers appear wehn connecting to charger or to PC with the USB cable.
anyone can help with anything that could solve this problem.
Thanks
Mahmoud
5 REPLIES 5
profile.country.RO.title
_alexdon_
Try to follow these steps: perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
ximahmoud
tried that.. nothing happened
_alexdon_
You need to have the device examined at a sony service:
alexdon
Mohammad91
Hello ,
did anyone know what is the problem Slightly_frowning_Face
 won't turn on and keep turn red light  when connected to charger , when connected to PC keep turn red and blue light
thanks
zers13
my xperia z1 wont turn on or neither the red light appear, but few minutes ago i charge it using my car usb and it works well. and i disconnet it until the batery drain out. but wont start charging when im using my ORIGINAL SONY charger. whats the issue? Help guys.
