My Xperia L is Hard Brick
Mak678
My phone going to hard brick i try do stock rom flash but flashtool no connect after i try do Pc Companian update through repair my phone option then download the update after some got a error i check from other computer and other network same problem is come...... Please help anyone this my First phone Capture.PNGCapture.PNG
5 REPLIES 5
Thommo
Genius
If your device can still enter Flashmode then it's not a Hard brick
Try performing a system repair using PC Companion
or see here to creare your own .ftf firmware file for manuall flashing via Flashtool
Mak678
i followed your instructions but same error is coming. i tried to create own ftf firmware but not sucessful. i download 6 different countery and differnet version firmware in flashtool come same error
Can i do any thing in fastboot mode
Thommo
Genius
What operating system are you using? and you may wish to use a different Pc
Mak678
i am using windows 7 64bit and other pc is windows 7 32bit
i using flashtools this error mostly comes
ERROR - Processing of partition-image.sin finished with errors.
INFO - Ending flash session
ERROR - ERR_SEVERITY="MINOR";ERR_CODE="0017";ERR_DYNAMIC="0x801E003F ";
then i check mark on partition then this error is come
ERROR - ERR_SEVERITY="MINOR";ERR_CODE="0016";ERR_DYNAMIC="Invalid TA";
Thommo
Genius
There is an issue that some have with 64 bit systems and Flashmode - Are you trying to repair via PCC or manually as the invalid items could mean that it's the wrong firmware for your exact variant of said model
