my x10 mini not started while battery is full charged.
gajodhar
my x10 mini not started while battery is full charged. My phone get off while i connected through PC. After removing connection from PC i try many times but can't restart. After that i put it in charge by wall plug , at first red light glowing for few minute and it turn into green. I charged it approx 4 hours. After charging i try again to restart the phone but can't boot. kindly help.
Alexander1
Try to press and hold the power button and the home button (middle key) at the same time for about 10 seconds.
If the phone still doesn't start, you could try to remove the SIM card and SD card and try to start the phone again.
If the problem persist, try to repair the phone software using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phones software > Press the blue link that says "Repair phone". Do this without the phone connected to the PC and follow the on-screen instructions in the program.
