My phone is not charging
Grantperia12
The charger is working fine and when i put it into the phone it knows that it's in their as it lights up but ther phone is still not charging can anyone help me?
4 REPLIES 4
Rado77
Yes  Slightly_smiling_Face
Rado77
Ohhh I forgot an answer Smiling_Face_with_open_mouth_&_closed_Eyes  It's a known bug, especially when you used ClockWorkMod which replaces chargemon. It's charging but you don't see it. % of battery status remains the same. You can see effect of charging by restaring phone. After that you'll see correct battery %. Anyway you can use USB cable and charge it from PC, where is % of charging showed allways correctly.
Grantperia12
Seems to be working now Thanks for your help Rado Slightly_smiling_Face
Rado77
No problem Winking_Face  I had this issue too and it was solved after reinstalling whole ICS via SUS. It cleaned everything and CWM was away....
