My new Sony Xperia S LT26i wont power on.
PandaTheory
Okay, so here is the problem. I just got my new Xperia S and I have not been able to turn it on.. not even once.
I tried holding down the power button for 30 seconds or longer, I've tried holding down power button + volum up for 5-10 seconds.
And nothing happend... I have been charging it for 2 hours now, and there is a red light on top of it..
Can anyone help me with this?
38 REPLIES 38
Thommo
Genius
Did you hold power and volume up untill you could feel 3 continuous vibrations
If that doesn't work try to run a repair using SUS from below
emma.extranet.sonyericsson.com/update_service_setup
As this doesn't require your phone to be turned on to repair
PandaTheory
I held the buttons down for 2 minutes and nothing happend.
And the update service was no good because windows wont detect the phone at all..
Thommo
Genius
You need to install PCC 1st then which will install drivers
www-support-downloads.sonymobile.com/Software%20Downloads/PC%20Companion/Sony%20PC%20Companion_2.10....
Then when you connect in flashmode which is volume down then connect usb lead it should then install the driver for it thus allowing you to use SUS to run a repair
PandaTheory
This didn't work either. The only thing my phone does is showing a red light.
how about if you connect it to the wall charger press and hold the volume up and hold it until it vibrates, once it does let it charge for an hour
PandaTheory
Tried that to and it didn't work, no big suprise...
Thank you for trying at least Slightly_smiling_Face
that's quite odd, this might be a dumb question did you try different wall chargers, usb cable and wall sockets?
PandaTheory
Quite odd indeed. I tried different wall chargers and cables... and everyone of the seem to work since the phone is displaying a red light.
is it a solid red light or flashing red light?
