so I probably have no place to post it here
the inability to multi select emails on gmail and delete them, like 400 5 at a time - I'm going to try and do it with my PC login but I thought this was worth a mention here even though it really has nothing to do with Sony
if anyone can offer a solution to this I'd be very humble with gratitude
I'll amend the number which is now 752 emails - I use a client to read my google mail - MS outlook so will look at some settings to see if I can rectify this but I am not holding my breath
The Gmail app does unfortunately not have any option to multi select, you have to select each email manually. The easiest way would probably be https://mail.google.com.
If you want to use MS Outlook to delete emails from Gmail i think you have to configure MS Outlook to use IMAP instead of POP. Also check the settings for POP/IMAP on https://mail.google.com for how emails should be deleted when using IMAP.
