I have used my MW600 for about 6 months and I have a couple of problems.
1) I can only connect one device. In the specs, it is said that MW600 shall be able to connect to two bluetooth devices simultaneously. But my can't talk to anything but my xperia x10 mini pro. This problem is really annoying since I have one X10 mini pro for private use and an x10 min as my jobb-phone. Now I still have to use two headsets or one headset and one handset...
2) Now the display is dead. Dead as in all black.
Are there any firmware up-dates I need to do or should I just consider my money wasted and let it Rest In Peace?
It has multi point connection.
But since the display is broken I would suggest that you contact your local support team to check if this is something that can be fixed within your warranty.
http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
