I have bought a new Sony tipo ST21i 3 days ago. When I tried to connect the phone using PC companion, it shows me an error as 'Error in installing MTP device'. I tried everything - updating windows media player, changing the settings on my phone from 'MTP' to 'MSC' and again back to 'MTP'. Nothing worked. Also, I tried it with and without my SD card. No use - Same result.
Any suggestions or solutions??
Thanks in advance.
Regards,
Absurd.
Have you tried re-installing PC Companion and switching USB port on your computer?
Yeah I did. It works great in other systems using Windows 7. I'm using Windows XP. I suppose that's not a problem.
Hello,
I have the same issue than you. Have you found any solution?
Thanks
Hello Samuel,
I've read and I have my Xperia detected as MTP but it is not able to install the MTP driver correctly. The same phone on Windows 7 works perfect.
Any other idea?
Thanks for all
Check this thread at XDA, someone with similar issues and some different solutions.
I am still struggling with the problem. I have been using mass storage all these days. I still could not find a solution for the problem. Have anyone found any solutions for it?
