Motion suggestion
Ram786
Motion suggestion
Their should be motions function
Like:-
1> Palm Swipe to Capture:-
Capture the screen by swiping it from right to left or vice versa with the side of your hand
2> Smart pause:-
Place your hand on the screen to mute incoming calls and alarms or pause media while the screen is on
->Handset Make/Model -:Sony Xperia Z5 Premium Dual Sim (E6883)
-> NON-ROOTED
> Android OS Version -: Android 6.0 (Lollipop)
-> Latest available software -: 32.1.A.1.163
-> Release started -: 2016-02-01
-> Operator, APN & Type -: Aircel GPRS,aircelgprs (2G)
-> Country -: India
-> Platform-: Android
-> The bug is-: Always
4 REPLIES 4
@Ram786
contact Sony directly with your suggestions >>> Local support
There are 2 ways to take screenshots, either power & volume down or using the small app.
Using the palm to swipe, will be complicated as if you touch the screen with multiple fingers/contact points, might change whatever you are trying to take the screenshot of.
Also, if you use 2 or more fingers to pinch zoom the homescreen it will allow you to remove multiple apps and widgets from the launcher without having to long press each.
Not sure if you are aware of this
Settings > call settings > smart call handling >
answer: bring the device to your ear
reject: shake the device
ringer off: place the device face down.
Ram786
Yes i know
smart call handling and
palm to swipe is easy
And i does not have to use if you use 2 or more fingers
https://drive.google.com/folderview?id=0B8TR5z3HUKSaeEZTU0VqeGxXMVE
@Ram786
Have you checked on the play store for third party apps, and also make sure to contact Sony directly
Ram786
I have already check
third party apps, but none of them work and even contact directly to sony but no response them
Sony Xperia Contact Center, Service Request: 1-24643511367
