Mobile Signal Issue
Prateek_Rana
Mobile Signal Issue
Hello, this below is the screenshot of my mobile battery usage for xperia P
WHY MOBILE SIGNAL IS GREY IN BETWEEN CAN ANYONE PLEASE HELP
Did mobile signal is turned off automatically ? i happens everyday and i dont use airplane mode ever
i stay at home all day not even going out or in roaming then why this happens ?
Also there are many small gry areas also in the mobile signal bar ..
PLEASE HELP
15 REPLIES 15
profile.country.RO.title
_alexdon_
Did you notice the battery going quickly down when the signal was presumably down?
alexdon
casimirfunk
No network coverage area? Or dead cell sites i guess?
zefs
Go to settings-power management-battery and click on cell standby.There you will find "time without a signal". What is the percentage shown?
florenzgonzales
do you have any phones in your house? try to compare if it happens the same with other mobile.try to disable extended battery mode just to see if your signal is now working without extended battery mode. try also repairing your software. if still persist try to also test using another sim card on your xperia P if the problem will still the same. hope it helps
Prateek_Rana
no friend . battery was fine still having the same problem
Prateek_Rana
nope. i am at home all day when i took screenshot
Prateek_Rana
it's only showing the percentage used
not the percentage without signal
is there an app to check this
Prateek_Rana
i reset the phone but still the same problem
i will try other SIM card also
Prateek_Rana
