mobile data traffic setting
hiapoorva_gmail
Hi Guys,
I have observed this issue from a long time.
At home i use the Wifi, once i get out i swtich on the data pack.. now my problem is... once i switch on the data settings it does not connect immediately... i keep it on for half n hour too it doesn not connect. but if i switch off n on the mobile then it works fine. this is happening everyday.
What can be done.
Pls help..:)
Thanks.
4 REPLIES 4
androidmaster
At first switch off the Wifi and after that switch on the data pack. Wifi and data pack will not work simultaneously. Do it and if the problem persist then let we know.
hiapoorva_gmail
I do that itself.. i first swtich off the wifi and then only swtich on the data pack... problem stillremains the same.. Slightly_frowning_Face
danielbosco
I am also facing same problem. And the mobile data speed compare to other device is very slow.
I have check by changing my sim and its still slow.
 Even tried inserting my sim into other device and its very fast.
Can you please guide me what might be issue with it. Because have a so nice phone but internet **bleep** to really bad.
xperiaz2
I used to face a similar problem even with the network when getting in & out of the lift. After i upgraded my phone to the latest 4.2.2 software the problem was automatically resolved. I would recommend u try it too.
