Mobile data connection issues
AlphaTrix
Hi
I just bought my Xperia P last week. Since I've been having connection issues. It started, as far as I can tell in such a short period of use with the wifi connection. When I would go out of range of my home wifi it would freeze, only fix was to reboot the phone. It would not switch over to mobile data at that point either so I had no connection at all untill I rebooted. I've since been trying to figure out why the wifi froze. I've reinstalled the latest phone update through PC Companion and I've factory resetted the phone on the device itself.
My wifi issues appear to be fixed after this however, and equally annoying, now my mobile data won't work. I see the H appearing next to the reception bars and arrows up and down appear next to it but no web page will load, facebook or mail don't work either. I've been trying going in airplane mode, just toggeling the data connection, rebooting the device, nothing works consistently. Sometimes mobile data will work, but more often it wil not.
I have contacted the store and they are willing to exchange the phone. However, I wanted to check here first to see if this is a common problem, if its a software issue, a new phone won't help much. If it is a software issue, is there anything I can do to fix it myself?
Johan
I would suggest that you check if the same problem remains using another SIM card in the phone, if yes you should contact your retailer to do the exchange.
