MMS problems
MMS problems
Can anyone tell me why my Xperia x10 mini (on o2 network) takes soooo long to send MMS or just says "queued for sending" for days? I have been on to o2 and checked all my settings are okay. Is there anything I can do to speed it up? Do I have to have a certain number of signal bars in order to be able to send MMS quicker or something? Ive never had problems with Sony Ericsson before, Im very disappointed 😞
5 REPLIES 5
gwhispererz
I do not know whether it will help if you play around with the Network mode, no harm trying with the 3 options available. You will be able to find that setting in Wireless & network>Mobile networks. Make sure you delete all mms on queue.
Another option is to do a Factory reset, be aware that this will wipe out all data in your phone memory.
Good luck.
Thanks for that - it seems to work better if i select the 3rd option - "GSM/WCDMA preferred" Slightly_smiling_Face
hi, i'm having the same problem but mine just say sending. tried what you suggested but it didn't work, i have a brand new x8 and picture msg has never worked. do you have anymore suggestions? thanks
gwhispererz
You mean you did a factory reset phone too and didn't work? Anyway, suggest you test with another SIM Card, if it works, probably you should ask for a replacement.
