Really missing volume settings
I don't mean to be rude, sorry about that.
Btw I'm using stock xperia dark theme.
It happened to me one time ! I rebooted and it went well again, right now, but I suppose is due to some residues of some apps !
It use to disappear after some time. Then I have to reboot to be able use it as normal.
After the Marshmallow update I lost the possibility to modify all three volumes (notifications, media, alarms) by using the vol buttons and selecting the drop down menu in the volume adjustment popup I had before Marshmallow (Z5 compact here but it's probably a common issue).
Now adjusting the volume with the physical buttons makes the popup appear but without the down arrow which opened the other 2 volume bars.
To lower the Media volume before entering a media app I must navigate inside the settings menu.
Is this change intentional? If so I don't understand the underlying idea.
no this is not intentional, it likely a bug,
try to repair your phone using pcc.
Hello!
After the update to 32.1.A.1.185 I saw that when my phone goes a little hotter from playing games the options for lower any sound for music or alarm just dissapears. Here is the picture. Right on the top of the screen.
And I do not know what is the problem of that.
I repaired with xperia companion but this bug just remains, I've noticed that it came after that last update 32.1.A.1.185, because before it didn't happened. For me it dissapears when I play game and the device gets little hotter. I have all latest updates on z5 and tried everything to remove this but it just keep getting back. You can only solve this if you restart the device or change theme, nothing else helps. I really hope they will repair this.
I have the EXACT same problem. I'm on MM 32.1.A.1.185. The arrow disappears randomly and the only way to get it back is by restarting the phone. Interesting bug... 😕
