Hi.
I have updated my z3 LTE tablet for the long awited Lollipop.
The main reason for my upgrade is multiuser/profile support.
After the update it seems like multiuser support is now added but profile/restricted Profiles is not supported. Which is a big drawback for families with kids😢
I'm sorry to hear that, I'll reply if I find something. Just double checking, you weren't able to flash the firmware excluding the baseband ?
This is SO messed up.
Just bought 10 Xperia tablet Z2 for classroom use.
First 10 of totally 60 needed. Had to buy 4G because Sony norway couldn't supply enough wifi models.
Not only did we purchase a more expensive tablet, it doesn't work the way we intended.
Restricted profile using Sony Xperia Configurator to set them up was the whole point.
Can I flash a Wifi firmware on it? Will not be needing the 4G function at all. ever.
Check the XDA forum for the FTF file
/t5/Xperia-Z2/How-to-manually-update-downgrade-root-2014-Xperias/td-p/593459
