Mini pro not recognized by PC
Hackeberga
I have a mini pro SK171 with android 4.0.4 Recently (after an android update?) I started experiencing this problem: there seems to be no communication between The PC (with Vista as the operative system) and my mobile. Earlier as soon I connected the mobile it was immediatly  recognized, now nothing.
If I in the mini pro go to "connection sharing and hotspot" the USB option to select the sharing via usb cable is inactivated (it can't be selected), and it says: "no USB is connected (this despite the calbe is connected and is actually charging the mobile phone from the PC.
Any suggestions?
Thanx
2 REPLIES 2
profile.country.PH.title
MarlonUk1
do you have pc companion and Sony update service installed?
try to use other usb ports
disable your firewall , antivirus
restart phone
try to give it a few momments to detect the device
go to device manager and refresh
try to clear mtpapp app on settings>apps>look for mtpapp clear data
Hackeberga
Thanks for the answer. I have pc companion and Sony update installed. I will try the suggestions you made and get back.
