I have the 2011 Mini that I updated with PC Companion a couple weeks ago to 4.0.4 I haven,t had any trouble untill yesterday . I cant download updates or anything from the android market. It goes to downloading and then never does. I also have found out that downloading something in the browser is also stopped. I can use the browser and watch videos all day long and in fact useing the phone now as the wifi hotspot typeing this disscution. I did a reset ...that did nothing...i also did a repair with pc companion and stuff the phone is doing the same thing. I have checked everything google has told me to check and they think it could be a software from sony interfiering with it. I need help as now that I have repaired the phone i cant get any of my apps back BECAUSE IT wont download from google play or the internet . thank you.
After the upgrade you should do the repair with SUS. Better to have a clean install. You will have to install all the applications again but it will work without problems. Some of the applications are not compatible with ICS also. Do the repair . Hope it helps.
