when you call, I have difficulty hearing the other party, and that's with different contacts.
Hi, Sounds like its not your mic its your speaker volume that is low. if you goto settings and sound, you can turn up each sound level. there is also boost caller sound fuction.
I do not think so, because it can not be, the sound of the other so as to cover the microphone with high sensitivity.
