Micro usb not working anymore
Houblonde
I can't charge my tablette z2, since the usb doesn't seems to work anymore.
Is there another way to chage my tablette, cause now, I can't use it anymore?
I tried a magnetic, but doesn't seems to fit ,  I guess it's for phone.
4 REPLIES 4
John-BR
Hi Houblonde
Welcome to the community.
If you aren’t able to charge the tablet through the USB port you can use a magnetic charging dock to charge it, here is the information about the compatible accessory.
I would suggest checking to see if this is a potential hardware problem. To use Xperia Diagnostics
Go to Settings > About phone > Diagnostics.
Tap Test device.
Select the Charging
Follow the on-screen instructions.
If it fails the test have a chat with your contact your Local support team as it will need to be serviced.
Houblonde
I do not have the diagnostic in this menu.
Maybe my firmware is not up to date? 10.5.1.A.0.283
But i can't update it tell me my batery is too low.
But thank you for the answer i'll try the magnetic charger.
Houblonde
I'm not sure anymore I have a z2, I fou d a video and I don't have this connector at the bottom.
John-BR
Happy to help. Slightly_smiling_Face
If you have on older version of the OS you can install the diagnostics tool directly here, if you still have enough battery.
If you do need to a look for a magnetic dock double check the model of your tablet as each of the docks are designed to work with a specific model of device.
