Micro SD card
Vennger
Micro SD card
My Micro SD card was recognised by my Xperia L when I put it in and most of the content worked - then after a month (aprox) the phone put up a message - Warning SD card unmounted unexpectedly. I hadn't done anything to the phone, but from then on, the phone won't recognise the card.  If I link it via USB cable, it can recognise the photos in a DCIM folder, but the phone keeps saying - "please insert SD card".
Is there anything I can do?
Jake-SonyXperia
Hi Vennger,
With the information provided, I suggest backing up the SD card to a PC if possible, and once this has been done I suggest using a PC to format the SD card.
Once this has been done, pop the SD card back in to the handset and see if the device can read it.
I hope this helps.
