I want to purchase a 64GB Micro SDXC card for my new Sony Xperia Z1 Compact and would like to get the fastest card (read/write speed) compatible with (i.e. useable by) the phone, but I do not want to waste money buying a card that has a faster read/write speed than the maximum speeds supported by the phone. What is the maximum read/write speed of the Xperia Z1 Compact for micro SDXC cards and what would you recommend?
@Heresy wrote:It looks that Sandisk Extreme card is good enough for Z1 Compact.
Extreme Plus doesn't work better.
Yeah, it was actually cheaper so no loss here
That's very interesting kind3r - Did you measure these read write speeds with the micro SD card while it was actually plugged into the micro SD memory card slot on the Sony Xperia Z1 Compact mobile phone? I.e., were your read write speeds actually measured using test software running on the Z1 Compact itself?
@J2014 wrote:That's very interesting kind3r - Did you measure these read write speeds with the micro SD card while it was actually plugged into the micro SD memory card slot on the Sony Xperia Z1 Compact mobile phone? I.e., were your read write speeds actually measured using test software running on the Z1 Compact itself?
It would be very helpful if you could answer my question above about the details of the speed tests you conducted, as I want to purchase a SanDisk 64GB microSD card but I really don't know whether to get the Extreme or the much more expensive Extreme Plus, but I do want a micro SD card which will give the fastest possible write and read times which the Sony Xperia Z1 Compact can handle.
Sorry for the delay, I used A1 SD Bench on the phone https://play.google.com/store/apps/details?id=com.a1dev.sdbench .
Thanks kind3r - That's very useful information!
Does anyone know if a z1 is compatible with a samsung micro sdhc uhs-132gb pro the device uses 3.0 and 2.0 ports and the read speed is 90mb/s the write speed is 80mb/s anyone out there who can advise please? Also I got a cheap 32 gb card on ebay and certain videos it will not play others it will I tried formatting still the same, it plays music all right pictures are fine but when I formatted this card it is only in fat 32 format I cannot change the format in any way, again any advice appreciated.
