mic not working
omar_haytham
mic not working
mic is not work
i have root on my phone and i have custom recover
and i think this happened because of this thread on xda
http://forum.xda-developers.com/showpost.php?p=53165575&postcount=66&nocache=1&z=6517119251657277
it's not work on all app and i can't answer the call, i can hear him only
but i can answer from headphones
so what i should to do ?
Tags (3)
9 REPLIES 9
Samuel1
Hero
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
omar_haytham
they say : the system modified !!!!
error (2003)
Sam
Legend
Legend
In this case it sounds like you have unlocked the bootloader, not just gained root access, please confirm.
What are your thoughts about this forum? Let us know by doing this short survey.
omar_haytham
yes.of course
i have to unlock the bootloader if i want to root my phone
omar_haytham
Sam
Legend
Legend
Sorry for the late reply, if you have unlocked the bootloader and I assume loaded a custom ROM on your handset then there is little I can do to assist as our authorised tools will not work with this handset due to the modification. You would be best to raise concerns with the source of the ROM you have loaded.
omar_haytham
so there's no Solution!!!!  Slightly_frowning_Face
Sam
Legend
Legend
Unfortunately these are the risks with making this kind of modification and why we do outline the potential hard to the device : of possibilities, however if any force was applied to the headset whilst it was connected to the phone this could lead to damaging the headphone jack.
http://unlockbootloader.sonymobile.com/
"Sony can no longer guarantee the full functionality of your device, and will not be responsible for any unsigned custom software being flashed to the device after the boot loader is unlocked. Certain functions and offerings in your device might cease to work, and performance might not be ideal. You might also damage your device permanently. In the worst case, unlocking the boot loader will cause physical injuries or material damage, for example, due to the device overheating."
omar_haytham
thank you my friend ^_^
