My SD card can only hold about 65 photos. I am always getting a message that my SD card memory is full.
When I check 'Storage' on the phone for SD Card, it shows:
1.85 GB Total Space
281 MB for Apps
76.54 MB for Pictures, videos
65.58 MB for Audio
17.31 MB Available
I should have about 1.5GB available.
I have only installed 2 apps, one was just a file manager so I could try to see what the problem is.
Any ideas on what the problem is, and how I can resolve it.
Thank you in advance.
Seems like there can be some kind of error with your SD-card. I recommend that you first of all try to format your SD-card. You can do it through your PC or in your phone.
PC: Right click on the SD-card when you are under "Computer" > select to format.
In phone: Settings > storage > unmount SD card > delete SD-card.
Note that all your content on the SD card will be deleted so make sure you have moved all you want to keep to your PC.
You can also try with another SD card if you have one extra available.
