Memory Issue
anilw
Memory Issue
Hi all;
see i feel the update made my life easier.. now my phone works better than previously and so far no major worries.. but i cannt select SD card as the memory location for camera....is it a bug or...
also i have app to record calls and another o record lectures.. in that also i cannot select memory card as i was supported in the previous version
2 REPLIES 2
arturiu
Can you see your SD card as mounted ?
(Settings - Storage - scroll down to SD Card - it should show how much space available)
If not, you may have do check the SD Card filesystem.
(use your PC to do that)
About camera, you can select SD Card in Settings (vertical dots)  - Tools tab (the 3rd after cam and vid).
Scroll down and you'll see Data storage option.
anilw
Hi Tks.... yes my SD is shown as mounted and i can transfer data to it..
i have unmounted and re-mounted but problem remains same....
i cannot acces videos on my SD card through "Movies".. but i have "MoboPlayer" it can access videos in  SD card..
