hi guy i bought sony xperia x8 can anyone tell me from where i find the games and application install in my memory card i cant find my memory card in my phone plz tell me in which option of phone i find memory card applications.
you need to press and hold the back button w/o releasing it
don't forget to mark the Correct & Helpful Answers
make sure you restart your compouter after you install Update Service
one thing more when i try to update my phone through pc campaign then after downloading updates in pc and when its strt to update the mobile then its give error that take out ur usb check the baterry is 50% off the mobile for 5sec and so n so why that error come and tell me the best way to update my mobile is i update from pc campaign or i install update service software in my pc for updation
use translate.google.com it'll be easier for both to understand each other
but after you run Update Service it will ask you to turn off your phone, remove the battery, wait, put the battery back on, press and HOLD the back button and DO NOT release it, while still holding the back button connect the usb cable and DON'T release teh back button
but i have to update my phone with upate service software or pc campaign which one is better for me
Update Service it's far more reliable, I don't quite understood if that was a question or statement. try translate.google.com
sorry that was a question can u plz tell me from where i should download update software in my pc
you just posted the link above
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
download it, install it, run it/open it
hi dear i done all these above steps but when i open link2sd then its gives the following menu(select the file system of yo....) then i select FAT32/FAT16 but after tht it give the error (ROOT ACCESS WARNING LINK2SD COULD NOT GAIN ROOT ACCESS IF U HAVE ROOT ACESS MAKE SURE YOU RESPOND ALLOW TO SUPERUSER PROMPT) WHICH ERROR IS THAT KINLDY TELL ME WT I DO and in the storage info when i see the 2nd partation its NOT MOUNTED kinldy telll me and my memory card is 2 gb so i make 1st partation of 1.36gb so kinldy tell me wt i do now to use linksd2 properly
and kinldy also tell me tht i have 2gb memory card so how can i make the partition
