Memory Card Not Working
ernestyeoyx
Am using a Samsung class 10 64GB SDXC for my Xperia z3 D6653.
Formatted to exFAT.
I can transfer media and all that , but the limit is 4GB . After I have used up 4GB of memory in the SD card , every file above this limit will be deleted .
But , the 4gb limit only happens to FAT32 isn't it ?
I need help fixing this,lurked around but haven't found a solution , Thanks !
Edit ; on 4.4.4 KK , 23.0.1.A.5.77 .
Edit 2 : Tried using USB Transfer cable MTP mode to sync Media Go , manual transfer , wifi transfer and used SD Card Adapter / Reader . Problem Persists
Tags (1)
14 REPLIES 14
profile.country.RO.title
_alexdon_
Have you tried with FAT32,just to check if after 4GB everything is deleted? I would suggest you to use a low level format tool and use a computer to format it.
alexdon
ernestyeoyx
Hey , Yes I Have. It was deleted.
Solution posted was formatting it to exFAT but apparently that doesn't do the trick for me at all.
It isn't hardware problem as well. Problem happens with my Z1 as well
_alexdon_
I wonder if this happens with other microSDs as well.
alexdon
ernestyeoyx
it does , thought it was SD problem , bought  another one and Same problem
Tags (1)
_alexdon_
Could you maybe check if the same occurs in safe mode?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
alexdon
Thommo
Genius
Are you sure the card is 64gb and not a fake 4gb made to look larger in size - Use h2testw to check
ernestyeoyx
Still persists
ernestyeoyx
Bought it from the Samsung store but meh .. yup tested its legit 62.4gb free space
_alexdon_
You should get less than 60GB after a conversion to binary. How do you get that much? I think you should stop by a sony service and let them take a look.
alexdon
