Hello!
(LT26w - 4.0.4 - 6.1.A.2.55)
After play in games (example Angry Birds) battery was down quckly because media server...
What is that?
The Media Server is a function that will scan trough the memory of the phone when new files are added. Most likely does the games you start up creates files which will make the M.S start up and scan. This should however solve itself as the games will probably not create files more then the first few times you play.
