mcafee locked my mobile and the screen is dead
how to remove\disable\anything mcafee
i have everything email , pass. pin but i cannot connect the mobile to internet as i cant see anything
any idea
thanks
You may need to perform a system repair also mcafee should not be a system app so can be removed
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
