Hi
I'm new to this forum and in need of help!
I have an Elm J10i2. Is there anyway I can manage my contacts from my PC, (ideally via bluetooth as I don't have a usb cable)?
My contacts on my phone are in a real mess and I can't face sorting them all out using the phone's interface!
I checked out the support page for a download but it only has software suitable for Macs, weirdly.
Any help appreciated!
thanks.
http://www.fjsoft.at/en/downloads.php If you download My Phone Explorer (MPE) to your PC, you can then sync your phone via Bluetooth to it in order to manage contacts and anything else that you need.Just make sure that your phone is connected to the PC via the BT Serial Port service and when MPE is installed go to: File--Settings--Connection--COM Port: here select the appropriate BT Serial Port from the drop-down menu.Hope this helps.
Thanks so mcuh for your great answer.
I had to buy a cable, but now it works perfectly!
Thanks again, kat
No worries.Glad it's working now.
