Hi dan9245,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
I suggest trying to clear the data for the apps to see if this helps.
Menu > Settings > Apps > All > Camera / Cameras > Clear Data
Once done see if this helps.
Let us know how you get on.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
I did the repair my phone on pc companion and still no luck... still stays black screen and then gets out and says camera unavailble still.
In this case,schedule an examination at a sony service:
